3 pt hitch plow
Bart
04-01-2004 01:25:25
Hugh Mackay, Wonder if I can get some expert advice on a 3 pt plow. I have a 53 Super M with Saginaw 3 pt. Should I get a 2/16 or a 3/16 or what should I look for for that tractor. Just want to do a few gardens. Thanks for any help. Dick in Vermont.
Hugh MacKay
04-01-2004 02:28:40
 Re: 3 pt hitch plow in reply to Bart, 04-01-2004 01:25:25
Bart: You indicated just plowing a few gardens. For that purpose I would tend to go with the 2x16 plow. I have never had any experience with Saginaw hitches, but one must remember you don't have a draft controled 3 point hitch. Without draft control I doubt if you would be very happy if you were doing a lot of plowing. For that reason I would stay with the 2x16, M will lug that along iregardless of draft.
Gardens in residential areas tend not to have the best drainage, room for turning often a factor. For those reasons plus you may as well only maintain two bottoms as three. If you ever decide to do a lot of plowing, get yourself a 3x16 or 3x14 trailer.
Bart
04-01-2004 12:15:01
 Re: Re: 3 pt hitch plow in reply to Hugh MacKay, 04-01-2004 02:28:40
Thanks a million Hugh. You're right, I really wouldn't have room to turn a trailer plow in most garden spots. A 2/16 should be plenty for what I need . Have a great day. Dick in Vermont.
