H4 Impulse
Jeff
04-02-2004 13:59:39
How hard is it to change an impulse spring in this magneto? Is there anything that has to be marked to keep in time before i start tearing it apart?
Thanks
jeff
Nebraska Cowman
04-02-2004 18:00:03
 Re: H4 Impulse in reply to Jeff, 04-02-2004 13:59:39
if you just pull the impulse you won't get it out of time. it is keyed on a tapered shaft. Now if you start taking the other end of the mag apart there are gears that need to be timed but they are marked.
