Radiator for an Early Super A
Jon with an H
04-02-2004 16:49:46
I have an early Super A, 1948, with the 113 engine and no water pump. I recently bought a radiator for it and it did not fit, turns out it was for a late Super A. bigger and different upper inlet. I am having a hard time with parts suppliers finding an early Super A radiator.
Will a radiator out of an A fit in my early Super A?
gene b
04-03-2004 00:45:38
 Re: Radiator for an Early Super A in reply to Jon with an H, 04-02-2004 16:49:46
The one from an A should work as they are the same as the early SA at least the one i had was the same.
CNKS
04-02-2004 19:30:24
Call OEM Tractor Parts 800-283-2122, just make sure you don't get the one for the Super A-1 as it is taller. The A radiator is 51149 DBX, I do not know if it will fit a Super A, I imagine it will.
Jim Becker
04-03-2004 08:05:50
 Re: Re: Radiator for an Early Super A in reply to CNKS, 04-02-2004 19:30:24
51149 DBX is the early A radiator. I will not fit a Super A. The late A radiator, 58124DBX, is the same as the early Super A.
CNKS
04-03-2004 12:48:24
 Re: Re: Re: Radiator for an Early Super A in reply to Jim Becker, 04-03-2004 08:05:50
Yes I wondered about that -- the "new" number is 358104R93 or 358437R92 or 359644R91.
Jim Becker
04-04-2004 07:43:21
 Re: Re: Re: Re: Radiator for an Early Super A in reply to CNKS, 04-03-2004 12:48:24
There aren't very many D numbers left. I don't have current numbers but the right radiator has to be whatever number superceded 58124DBX.
CNKS
04-04-2004 17:57:06
 Re: Re: Re: Re: Re: Radiator for an Early Super A in reply to Jim Becker, 04-04-2004 07:43:21
My parts book says those 3 numbers "will work for 58124DBX".
