H head bolts needed
Dan
04-03-2004 15:00:03
I'm in need of three head bolts (studs). I actually need the short ones, but the long ones will work.
Thanks,
Dan
Jonathan Mirgon
04-04-2004 22:29:16
 Re: H head bolts needed in reply to Dan, 04-03-2004 15:00:03
correct me if I am wrong guys but what would be wrong with buying some grade 8 studs for a dollar or so each ? The end that screws into the block are a fine thread and the nut end on top of the head is a course thread, the worse thing you could have to do is buy the nuts too.
DAN. R.
04-04-2004 17:08:47
DAN I HAVE SOME HEAD BOLTS. FOR THE PRICE OF SHIPPING, I WOULD SENT YOU 3. THAT IS 3 USED ONES.
Dan
04-04-2004 07:16:43
CNKS, I don't know where you get your Case IH parts, but I work in parts at a Case IH dealer and they are no longer available from Case IH as well as the Depot and DPNI. If you have a source or different part number, I would appreiate any info.
Thanks
Dan
Roger WI
04-04-2004 20:06:10
 Re: Re: Re: H head bolts needed in reply to CNKS, 04-04-2004 17:40:10
CNKS, I just bought one from the Case-IH dealer in Menomonie, WI two weeks ago. The price was $7.31 each. Roger
CNKS
04-03-2004 18:28:48
Case-IH has them, they are expensive, you might try Bates Corp. IMO it is not a good idea to use used ones off someone else's tractor, as they stretch, and you don't know how many times they have been tightened. That said, I haven't replaced any of mine when I worked on the heads.
F-Dean
04-04-2004 09:07:56
 Re: Re: H head bolts needed in reply to CNKS, 04-03-2004 18:28:48
So what it they stretch! The torque is the important measurement.
CNKS
04-04-2004 17:43:48
 Re: Re: Re: H head bolts needed in reply to F-Dean, 04-04-2004 09:07:56
My understanding is that they could break later, or perhaps result in leaks. More than one opinion on this.
