H oil ?
Chris Brown
04-03-2004 16:51:09
I drilled a dipstick tube in my H block,got me a distick in it and am fixing to make the low and full marks on it,but heres where I screwed up, while I had the oil pan off I brazed two patches over the holes where the drain cocks came off,now I don't know where full and low is and I don't know how much oil it holds. How much oil does an H hold with a new empty filter? Thanks
Chris
04-04-2004 13:29:01
 Re: H oil ? in reply to Chris Brown, 04-03-2004 16:51:09
Thank you
CNKS
04-03-2004 18:24:56
Approximately 5 quarts to the add mark, 6 quarts to the full mark. If I put 6 quarts in mine, about 1/3-1/2 quart will drain it down to the level of the upper petcock. So, in my opinion the crankcase "capacity" to the upper petcock is about 5.5 quarts. Just make the full mark at 6 and you will be ok.
sammy the RED
04-04-2004 10:08:13
 Re: Re: H oil ? in reply to CNKS, 04-03-2004 18:24:56
My Farmall H manual says 6 quarts.
