Where to buy engine parts?
Loren
04-04-2004 18:03:40
Now that I've got the B torn apart and need pistons/sleeves where have you folks found is the best place to shop? Also, can I put the high compression pistons in this flattop motor without changing other things? Loren
Zak
04-05-2004 06:11:39
 Re: Where to buy engine parts? in reply to Loren, 04-04-2004 18:03:40
I've used Weber's twice for piston sets. Once for my 34' F-12, and again recently for my 55' 300. Both times, the kits were in excellent shape, and were reasonably priced (and I shopped around, trust me!) -Z-
gene b
04-05-2004 02:52:55
Kits start at around 300.00 so look around and yes you can go with hi-dome pistons but you mite need to go with a distribitor to get the hi-dome engine to start.
John *.?-!.* cub owner
04-04-2004 20:52:00
Having trouble posting a reply, try the link below
Jeff_MI
04-04-2004 19:07:54
Little Red Tractor Company. Type this name in Google.com and their web site will pop up. I used them and JP Tractor Salvage for my BN.
BIG JOHN
04-04-2004 18:48:56
Parts of the Past - Tom Underwood - 785-749-5231
This guy has 4 warehouses of NOS parts, and is very reasonable.
GOOD LUCK
James Williams
04-04-2004 18:21:03
Loren,Parts are avalible through any parts supplier,If you have any 3in flat top pistons you dont want,I sure could use them.
