460 utility shifter problem solved temporarily
ken
04-04-2004 19:28:38
well took the whole shifter off the 460 today and my problem of missing the gate from rev to first ended up being the bracket that holds the gates together,the bolts holding it were loose and it could move forward and back.after seeing this had to take off the seat and battery and pull the top of the trans loose and pry up on the front to get a breakerbar and socket in there to tighten the bolts,but the lockdown tangs were in the way and couldn't get them as tight as i'd like so looks like i have a project for next winter.and it must have been loose since i got it because it's never worked this smooth since i've had it.
Chris
04-05-2004 05:25:17
 Re: 460 utility shifter problem solved temporarily in reply to ken, 04-04-2004 19:28:38
Hey Ken!! haven't been here for a while glad to see you got your 460 U up and going..mine is up and running although I didn't get to get all the stuff done I wanted to this winter she should be able to work. I am on my last hurdle...I hope...I have to figure out this fast hitch setup...Previous owner rigged it...now I need to get it functioning properly....If its not too much trouble could you take a look at yours and tell me this...when you pull the hitch back(like when you have a load on it) does the triangular piece of metal that holds that ball up under the belly come all the way back and bottom out on the belly housing of the tranny?? Maybe I can get you to take some pictures for me. Oh by the way...I have some extra manuals and some seals that Bates corp sent me by mistake if you are interested.
ken
04-05-2004 06:01:27
 Re: Re: 460 utility shifter problem solved tempora in reply to Chris, 04-05-2004 05:25:17
hey chris,yeah i'm interested in your manuals ,and i'll take you some pics today.send me a message( titled 460 ute) to kjmoore66@hotmail.com and i'll return the pics.it will be probably around 8:00 or so central time.thanks
TDK
04-04-2004 21:29:21
Glad you found the problem, Ken.
