(H) rod orientation
Jonathan Mirgon
04-05-2004 06:13:12
Was wondering the correct way to reinstall the rods on my (H). the only markings that I see on the rods are punch marks indicating 1,2,3,4 cylinders. The rods are off set, if I remember right the cap faces the intake side, but I just wanted to double check beffore making a huge time consuming mistake.The book I ordered 3 weeks ago has still not arrived !
thanks,
Jonathan Mirgon
mike in mn
04-05-2004 10:48:53
 Re: (H) rod orientation in reply to Jonathan Mirgon, 04-05-2004 06:13:12
one thing that is easy to remember if you don't know is that the number on the rod and on the cap always faces the cam shaft.
ChadS
04-05-2004 07:10:59
The longer side of the rod, not the cap side, will be on the side of the camshaft. ChadS
riverbend
04-05-2004 07:10:21
The flat spot where the rods and caps are marked goes towards the cam. Use 0.005" feeler gauges along side the rod / cap joint to make sure they are aligned properly when tightening the rod bolts (40 ft. lb.). If they feel too tight (slightly twisted), remove and reinstall the caps.
