IH factory wide front
Daryl
04-05-2004 07:21:07
Will an IH Factory wide front off of a 1256 fit a 656? Is it built stronger than one that originaly came on a 656?
GP
04-05-2004 09:03:24
 Re: IH factory wide front in reply to Daryl, 04-05-2004 07:21:07
Exact same thing. It will bolt right up. The 1256 had 8 bolt hubs originally, while the 656 had 6 bolt. That's the only difference.
RPM
04-05-2004 09:32:23
 Re: Re: IH factory wide front in reply to GP, 04-05-2004 09:03:24
Also bearing sizes.
Daryl
04-05-2004 12:04:27
 Re: Re: Re: IH factory wide front in reply to RPM, 04-05-2004 09:32:23
RPM. Are the spindles the same size?
RPM
04-06-2004 10:41:26
 Re: Re: Re: Re: IH factory wide front in reply to Daryl, 04-05-2004 12:04:27
Very unlikely, all 656 early Farmalls had 3/4 nf threads, later WFA had 7/8 nf, they made a parts conversion but was kind of pricey, most 656 were with tricycle fronts, they made a running change at serial 41971 and went to 7/8 on factory installed WFA, but stayed with 3/4 on tricycle.
