Int. 450
jjw
04-05-2004 09:24:59
WHat's approx value and hp for a Int.450 ??
Marv
04-06-2004 19:37:58
 Re: Int. 450 in reply to jjw, 04-05-2004 09:24:59
Depend on several items. It is a $1000. tractor if the engine is good. However. if it has PS, fast hitch, factory wide front, and a good TA, then the value is $4000. Take into consideration the tires. Back to the TA, consider that that tractor is 30 years old. If the TA has never been rebuilt, it is probably no good. A repair on it alone is $1500. Marv
Hugh MacKay
04-06-2004 17:41:38
jjw: The horse power will be in the low 50s range, pto probably 53-54 and drawbar probably 48. On value it will vary in different locations. Condtion will play a big roll. Best to compare that in your own area.
