Sloppy steering on F12
Ole Possum
04-07-2004 05:31:09
Is there a way to adjust the play out of the steering box on my F12? I have looked thruogh my manuals several times and still can't tell.
Zak
04-07-2004 19:37:32
 Re: Sloppy steering on F12 in reply to Ole Possum, 04-07-2004 05:31:09
Another common thing to do is to flip the steering sector gear on it's shaft. This places the worn section in the front and the "new" section in contact with your worm shaft. This has been covered in many posts recently.
jason
04-07-2004 09:51:57
You might check to see if the bearing and nut on the end of the shaft are tight.
