broke a rear wheel
dw
04-07-2004 15:41:08
Broke the cast rear wheel and wedge on my M Farmall plowing today are these hard to find is this common just got this tractor first farmall any ideas thanks DARRELL
John (AZ)
04-08-2004 06:19:33
 Re: broke a rear wheel in reply to dw, 04-07-2004 15:41:08
I've been told that this is commonly caused by not tightening the axle bolts enough.
john d
04-07-2004 20:37:42
Since this is a working tractor, I'm assuming you may not be too picky about keeping it in truly original form. If you can find a set of wheels/rims/tires for a 400 or 450 at a reasonable price, you might consider them, as they are an 8-spoke wheel and a bit tougher than the 6-spoke found on your M. They'll also have the newer style (and perhaps wider) rim. The axle size should be the same.
pcy
04-07-2004 18:27:00
ive got a complete 450 tranny and rearend, both cast centers, come get it for 150 bucks, and have some extra parts
Where?
04-07-2004 17:45:59
Where are you? How many do you want, I've got 2?
DW
04-07-2004 18:03:10
 Re: Re: broke a rear wheel in reply to Where?, 04-07-2004 17:45:59
IM in Morgantown KY 20 miles north of Bowling Green
scruffy
04-07-2004 16:36:52
I've replaced two, seems that when I put new tires and/or chains on these old girls, the traction is more than they have seen in fifty years and old casting let go.
I was able to find a wheel and block at every wrecker I tried. $100 Can.
NDS
04-07-2004 15:46:30
They should not be hard to find. Have heard that this is common problem but in over fifty years around Hs and Ms have never seen one broke and we ran heavy mounted cotton and corn pickers.
Dick Davis
04-08-2004 04:13:14
 Re: Re: broke a rear wheel in reply to NDS, 04-07-2004 15:46:30
All good advice so far, one caution 400 or 450 wheels won't take M deep "V" rims. The rims that fit 300- 450 rims are flatter in design and will not interchange with H-SMTA wheels. So if you elect to change you need the whole set up - might significantly increase the cost. BTDT Dick Davis
scotc
04-12-2004 17:17:19
 Re: Re: Re: broke a rear wheel in reply to Dick Davis, 04-08-2004 04:13:14
wouldn't it work to just use the other style wedges too?
