Order Farmall Cub Parts Online
Drawbar on cub
farmallman
04-08-2004 16:59:29
Is it possible to switch the drawbar around so i can pull empty wagons around (little ones :) ). If it is possible, how do u do it?
Rudi
04-09-2004 16:47:24
 Re: Drawbar on cub in reply to farmallman, 04-08-2004 16:59:29
third party image
If you go to the manual server at the link below and have a look at the owner's manual or the Cub-193 Moldboard Plow manual it will show you very clearly how to do that.
Hope this helps
Tom w
04-08-2004 17:08:04
The draw on a cub can go both forward for plowing and to the rear for pulling something. You just swing it around and move it to the rear bolt holes
farmallman
04-08-2004 17:10:25
 Re: Re: Drawbar on cub in reply to Tom w, 04-08-2004 17:08:04
What rear bolts?
49 Cubber!
04-08-2004 17:44:53
 Re: Re: Re: Drawbar on cub in reply to farmallman, 04-08-2004 17:10:25
Look on the housings where the drawbar is mounted.At the back of those housings there should be two more bolt holes!
farmallman
04-09-2004 18:48:19
 Re: Re: Re: Re: Drawbar on cub in reply to 49 Cubber!, 04-08-2004 17:44:53
my drawbar is hooked on the back two bolts (when you are looking at it from the rear. Do i take only the drawbar off or the plates too? Also, mine has a lever to lower and raise it. it also keeps it from flopping around. Where does that go?
