Looking for 460 Injector lines
CJ
04-09-2004 16:47:02
I am looking at a Farmall 460 that the owner claims needs new injector lines. The sheetmetal is great and it has run recently and has good tires and the fast hitch. What would be a fair price to offer for this tractor. Also, where could I get new injector lines and what type of cost am I looking at for that. Thanks in advance.
CJ
Gatz
04-10-2004 13:20:31
 Re: Looking for 460 Injector lines in reply to CJ, 04-09-2004 16:47:02
Don't think you will need new lines. I can't see those going bad. Maybe if something has been rubbing on them they could be bad. If so I would call a tractor salvage and see about price. He maybe talking about the injectors themselves. If you replace them yourself you can expect about $90 each. That is just the valve assy. inside the injector. Does it miss or have white smoke?
Price maybe $1800-$2500. Look for bad TA
Excessive engine blowby Not going into or staying in a gear. Could mean bad gears and bearings and there is usually more than one that goes bad. $$$$$$
All these can add up very quick. Just look it over good.
