Farmall 300 Propane Tank
Don Tucker
04-09-2004 17:09:45
I have Regal valves that leak out the fuel and can't keep fuel in the tank. Can these valves be rebuilt or have a replacement kit? Where can I get these fixed. Thanks, Don (N.W. Ark)
Van in AR
04-10-2004 04:59:02
 Re: Farmall 300 Propane Tank in reply to Don Tucker, 04-09-2004 17:09:45
M T is right, LP suppliers can get you the parts for a rebuild to new valves your choice in several brands. When I changed out my valves I ran the BBQ off of the tractor tank until empty. Nothing better than Farmall steaks, what a versitile machine!
Van
MT Pockets
04-09-2004 20:12:15
Don, are you sure it's not Rego? If it's the original valves I think it's Rego, and they can be repaired as well as most other brands. Your LP gas supplier is who you need to see. The same kit will fit both the liquid and vapor valves unless one has been replaced with a different brand. Your tank will have to be empty. I hope thus helps. Steve.
