play in steerin. Swartz wide front
Kelly C
04-09-2004 19:46:32
I have some play in the steering on the left side tire. There is about 32nd inch of wear were the steering knuckle arm attaches to the pivot shaft.
Trying to figure out what one of the 2 parts are worn.
Does the arm wear 1st? Also do you know where to get replacement swartz parts?
K Smith
04-10-2004 18:20:01
 Re: play in steerin. Swartz wide front in reply to Kelly C, 04-09-2004 19:46:32
Bates corp in Bourbon, IN is a swartz dealer. Their # is 1-800-2482955
Rick(MN)
04-10-2004 12:59:39
Kelly, the best would be to pull arm and feel the splines for wear. Not the best fix, but many have been welded solid to remove the play. Also, if you havent found a bale fork yet, get back to me. I have a New Holland here.
