Hand Crank for 130
Tom Coughlin
04-10-2004 06:47:56
I treid mounting a hand crank and bracket on my 130. The problem is, the electrical panel is in the way. Pictures in the owners manual shows the crank extening 1 inch beyond the back of the panel. What's wrong? I imagine the hand crank mounting config. is the same for the SA, 100 and 140 Thanks is advance.
Hugh MacKay
04-10-2004 19:12:38
 Re: Hand Crank for 130 in reply to Tom Coughlin, 04-10-2004 06:47:56
Tom: For some strange reason that crank doesn't fit in there as neat on the 130 as on SA. I always carried my crank for 130 with the handle pointing to rear and laid over towards fender. There must be enough of design change to prevent this. I don't even carry crank on 130 anymore and don't even have one for 140. I don't know the remedy, just wanted to let you know, you are not the only one with this problem.
