Seat shock questions
BillWV
04-10-2004 20:00:57
The seat shock on my Super C has no compression damping and tons of rebound damping. Is this normal, or is the shock worn out?
Also, 'bout how much should the seat spring compress? I suspect mine is sagged out, it just about bottoms with me on it (190 lbs).
Thanks,
Bill
Nebraska Cowman
04-11-2004 12:56:43
 Re: Seat shock questions in reply to BillWV, 04-10-2004 20:00:57
you might want to take your shock into an auto parts store and see if you can find a same size gas shock that has spring resistance.
CNKS
04-11-2004 12:49:01
OEM Tractor Parts has both -- 800-283-2122. IH used to make a light, medium, and heavy spring. I think all the aftermarket ones are heavy, should suit you fine, but you will still squish it down most of the way.
