Should I flush my H radiator like the book says??
John
04-11-2004 18:54:05
I was wondering if I should flush my H radiator like the book says with washing soda? My block drain plug appears to be stuck pretty good (Probably never taken out) and don't know if I would be able to get all of the water/washing soda out unless I get the block drain plug out. I put new antifreeze in it last year, drained and strained it a few times and now there is hardly any sediment in it. The tractor runs cool. Has anyone had any horror stories about removing the block drain plug? Also, I am pretty sure the water jacket has never been off, has anyone had problems with taking the water jacket off? Thanks!!!
aaron
04-12-2004 13:03:42
 Re: Should I flush my H radiator like the book say in reply to John, 04-11-2004 18:54:05
use a solution of 1 part Vinegar to 6 parts water. Safe, easy way to flush a block and it will not hurt if you cannot flush all the solution out the botton drain plug.
Andy Martin
04-11-2004 19:19:26
With modern antifreeze, which has excellent neutralizers and corrosion inhibitors, I'd leave well enough alone.
