Farmall H Transmisson Leak
Dennis
04-11-2004 19:59:00
I have a Farmall H tractor that leaks transmission fluid from the front shaft area between the "lift all" pump and the transmission. I plan on repairing it. The manual I have does not explain the procedure. Does anyone one have experience on this matter?
SGT K
04-12-2004 05:44:50
 Re: Farmall H Transmisson Leak in reply to Dennis, 04-11-2004 19:59:00
Dennis,
This isn't too bad of a job. I used a transmission jack with 2x4's wedged under the pump to lower it. The bolts that hold the drive shaft on in the back next to the transmission are tapered. After you take the nuts off put a wrench on the and smack them with a hammer, or leave the nuts loose, to protect the threads, and get a crow bar behind them and give them a whack.
Don't get discouraged with the drive shaft if it doesn't fall right out, it will come, but you have to hold your mouth just right.
The botom shaft, which turns the lift-all, has a notched end that will turn out.
When you get all of this out its a good time to check and adjust your clutch. I believe you can actually replace the disc at this point. (Someone please correct me if I'm wrong.)
Good luck
Paul
Michael Soldan
04-11-2004 20:09:19
Dennis, you need to remove the belly pump and then undo the drive shaft via the four bolts. This done you remove the flanges on the seals( you may as well do both shafts pump and driveshaft) A pipewrench will turn the flanges out , then you can pick out the seals and tap new ones into place. getting the pump out is the tough job, its heavy. Good luck from Mike in exeter Ontario
