farmall h wide front-end
Zach Perry
04-12-2004 09:31:56
Will a wide front off of a IH-400 fit an H. I was told that the 400 did not offer a wide front? If it will fit are there any changes nessary to make
it work?
Zach Perry
04-14-2004 09:45:54
 Re: farmall h wide front-end in reply to Zach Perry, 04-12-2004 09:31:56
Thanks for the help and the info. I will see if I can make it work.
42FarmallH
04-12-2004 18:29:00
I took a Schwartz wide front off of a 450 and put it on my H. Worked good.
Original IH would be more difficult. The casting for the rear stay rods is too wide for the H frame. You would have to build an adapter plate - also will need to change the steering arm to fit the H.
Just buy a Schwartz, they are built better anyway!
CNKS
04-12-2004 18:14:24
I hope someone gives you a straight answer. I think it will fit, but it is not a direct bolt on, so don't take my word for it (then why did I answer?) All letter series and numbered series Farmalls except the B were available with a wide front.
Dave_ Id
04-12-2004 10:15:24
I have an extra wfe for you.. I'm in the Idaho panhandle
Tom
04-20-2004 16:20:05
 Re: Re: farmall h wide front-end in reply to Dave_ Id, 04-12-2004 10:15:24
Hey Dave-Id,
Do you have a wide front end for an H?? I got confused with all the talk about wives?? How about some details on the H front end if you do have one. Thanks
wfe or wife??
04-12-2004 12:07:14
Dave, do you have an extra wife as well. You can ship her by Greyhound.
Dave_Id
04-12-2004 12:12:12
 Re: Re: Re: farmall h wide front-end in reply to wfe or wife??, 04-12-2004 12:07:14
I have an X-wife you can have, but you'll have to come get her. She's a good worker out in the woods, but doesn't take any interest in tractor restoration.
wfe or wife??
04-12-2004 12:25:45
 Re: Re: Re: Re: farmall h wide front-end in reply to Dave_Id, 04-12-2004 12:12:12
Sounds like she might be heavy-duty. I really don't want to go to the freight terminal to take delivery. She probably wouldn't like being shrink-wrapped to a pallet anyways.
