Where to get new rims for my Super C Farmall??
Tyler-MO
04-12-2004 16:40:22
Hello all! I am normally found on the "Green" message board, however we have one lone Red tractor that has been in the family since it was new in 1952. We need rims all the way around. Any suggestions for where to look new or used. Mine had calcium chloride in the rears and the fronts are beat up. I think the rears are 12.4x36 and maybe 5.50x15 fronts?? Anyway if someone has suggestions I am all ears. Thanks
Tyler in Missouri
gene b
04-12-2004 17:41:02
 Re: Where to get new rims for my Super C Farmall?? in reply to Tyler-MO, 04-12-2004 16:40:22
You need to measure what size you have on the rear. The front ones do they have ears riveted on or do they fasten to the hub with a clamp? The front would be 3x15 but you need to measure how wide the rears are and they will be harde to find as they have ears fastened on. The width of the rears can vary depending on what was ordered when tractor was new from factory.
old
04-12-2004 16:47:15
Richard Erb may have them his phone number is 417-859-2586 hes around the Marshfield area. Or you could also check with value bilt they also have them. I know other places in Missouri depending on where you are in the state
