Order Farmall Cub Parts Online
Cub Cadet #126 clutch chatter Problem???!!!???
Red
04-12-2004 18:54:55
When I put it in gear with the pedal down it shakes a little and grinds slightly. When putting it from low to high range it grinds like H....Is the clutch gone of can this be adjusted out.Are new clutches available.Thanks Red
Rudi
04-13-2004 06:59:56
 Re: Cub Cadet #126 clutch chatter Problem???!!!??? in reply to Red, 04-12-2004 18:54:55
third party image
For Cub Cadet parts (IH Cadets) try Carter and Grunewald. www.cngo.com. They have a ton of stuff
Bill Perry
04-12-2004 20:55:04
Very carefully oil the spring and mechanism at the clutch disc area obviously not getting oil on the clutch disc or the pressure plate. Mine will grind gears etc. if I do not keep this area lubricated. Adjustment is usually not necessary for me. The clutch not releasing even though the clutch pedal is depressed causes the gear grinding. I haven't experienced the vibration or shaking.
