544 D fuel tank problem
Tim (ny)
04-12-2004 21:08:04
I bought this tractor last year, and while bush hogging it appeared to run out of fuel. The guage read 1/4 and I checked with a stick and sure enough, there was a good quarter of a tank left. I added fuel, bled the lines and filters, and it started right up and ran fine. I checked in the tank, and there's not a high riser tube that would prevent the last quarter tank of fuel from draining. Does this make sense to anybody? Is there something else I'm overlooking?
MEK
04-13-2004 05:59:24
 Re: 544 D fuel tank problem in reply to Tim (ny), 04-12-2004 21:08:04
If you're not on level ground, the fuel could have sloshed away from the pickup.
tim(ny)
04-13-2004 07:07:58
 Re: Re: 544 D fuel tank problem in reply to MEK, 04-13-2004 05:59:24
Nope, I was on a hill when it first started to blubber, so I turned downhill and headed for the barn. When I got home it finally quit on the level.
