Starting a IH706D with German 310 engine
Barry
04-13-2004 03:48:58
Hi
We have a less than loved IH706D with the German 310 engine. Have just installed a new top end kit in the 310 engine, and put it back together. However, she won't start! We're running just the basic motor - most of the electrics are disconnected. The engine turns OK, but won't fire even with an ether spray. In that case, can rule out the pump and the injectors. Any ideas?
Saw a reply in the list about recessed valves being a problem??
Any really obvious gotchas here, 'cos I think we have fallen for one of them...
eg what tension should the head bolts be at?
MPJ
04-13-2004 17:02:38
 Re: Starting a IH706D with German 310 engine in reply to Barry, 04-13-2004 03:48:58
Check you valve adjustment. If the valves are over adjusted it won't have any compresion and thats why nothing will fire.
TP from Central PA
04-13-2004 06:30:56
I'll trade you straight up for our 706 with a D282(Smile)..... ...
farmallgod
04-13-2004 05:36:05
You didnt mention whether or not you bleed the injectors?
Barry
04-13-2004 15:36:14
 Re: Re: Starting a IH706D with German 310 engine in reply to farmallgod, 04-13-2004 05:36:05
I'm not the mechanic - but we took one of the injectors out, and there was diesel spraying out of that. There was also diesel dripping from the return feed line to the fuel tank.
However, I can't say that we actually bled the injectors. Good idea! Thanks.
JH
04-13-2004 16:20:49
 Re: Re: Re: Starting a IH706D with German 310 engi in reply to Barry, 04-13-2004 15:36:14
u need to find a c-263 gas suckin' hawg and put in that pig and then atleast you'll know it will run and it will be a lot simpler to work on.. plus they start much better... just pry your wallet open everytime u need to run her cause you'll need to put gas in that pig, but it will pull like hell... so, sell thaT diesel and get a gas..... ... gas power!!!!! !!!!! !!!!!
Bernard le mécano
04-13-2004 18:47:54
 Re: Re: Re: Re: Starting a IH706D with German 310 in reply to JH, 04-13-2004 16:20:49
Hi, just an idea, is the injector return line is below the injector? You can install the injector with the return line over there,on this engine, but the engine wont fire. Bernard le mécano
