Get Pulley off Generator on H and BN
Steve W (NY)
04-13-2004 16:12:10
One of my neighbors graciously gave me a working generator off his H (converted to 12V) to use on my BN. The generator and regulator is the same, except the pulleys are different. I need to remove the nuts, and swap the pulleys.....I don't want to mar these up, so does nayone have a technigue to hold the pulley, and or pull the pulley....
Thanks in advance,
take Care
Steve
Jed
04-15-2004 07:14:18
 Re: Get Pulley off Generator on H and BN in reply to Steve W (NY), 04-13-2004 16:12:10
My success rate at removing them allows me to advise that you use dynamite.
Bob
04-13-2004 16:55:55
Use an impact wrench to loosen the nuts. Set the generator on it's back and and apply PB Blaster to the pulley to shaft joint for a couple of days, if needed. They are not a press fit, although they are keyed, and with penetrating oil and light tapping using a wooden block, they should come off without too much trouble.
