Farmall A Clutch
Jim
04-13-2004 16:34:32
After installing a rebuilt Clutch in my little"A", it seems harder to get the machine in gear now. For some reason it seems like the Tranny gears do not want to quit spinnning enough to get the thing in gear. It has 1 to 1-1/4" free play before clutch disenguages like the Owners Manual says. Any ideas?
gauger
04-14-2004 05:36:30
 Re: Farmall A Clutch in reply to Jim , 04-13-2004 16:34:32
I noticed the same thing with the super A I did last year. New everything including the pilot bushing and throwout. Could it be the clutch itself?? Hmmmmm mmmmm
Haas
04-14-2004 05:35:49
Most likely your problem is due to the pilot bushing dragging and keeping things turning. If there is the slightest burr or roughness on the end of the drive shaft that goes in the pilot bushing in the end of the crankshaft, you will have this problem. A heavier oil in the the transmission to give a little more drag will help. Other than that, you just have to be patient and wait a few seconds for things to stop turning. I have this problem on one of my tractors and that is what I do, just wait. After it is in gear, no problems changing between gears.
gene b
04-13-2004 19:26:24
Did you rep;ace the pilot bearing in the crankshaft?
Jim
04-14-2004 18:53:10
 Re: Re: Farmall A Clutch in reply to gene b, 04-13-2004 19:26:24
Same Pilot Bearing, looked like new. Rebuilt clutch, same pressure plate. Do new Pilot bearings drag a little?
