1949 Farmall M radiator drain?
jamie
04-13-2004 18:32:06
anybody know a good place to get a plug for the radiator drain of an or what I can use for one?
Paul...
04-14-2004 04:26:49
 Re: 1949 Farmall M radiator drain? in reply to jamie, 04-13-2004 18:32:06
All it is, is a short piece of 3/8" NPT and a cap.
I like to use brass, but any short nipple and a cap, or just a pipe plug will work.
CNKS
04-13-2004 18:50:45
It's just a piece of pipe -- take it to a hardware store and get a new one.
jamie
04-13-2004 18:59:06
 Re: Re: 1949 Farmall M radiator drain? in reply to CNKS, 04-13-2004 18:50:45
haven't messed with it really... so does that pipe just screw out of the fitting on the radiator or what?
CNKS
04-13-2004 19:19:18
 Re: Re: Re: 1949 Farmall M radiator drain? in reply to jamie, 04-13-2004 18:59:06
The pipe has a cap on it. On all I have ever tried to remove the pipe comes out with the cap. Put a pair of vice grips on it and carefully turn. I doubt if the piece it screws into will break, but anything is possible on 50+ year old metal. To be safe you might hold the pipe and try to remove the cap.
jamie
04-13-2004 19:24:24
 Re: Re: Re: Re: 1949 Farmall M radiator drain? in reply to CNKS, 04-13-2004 19:19:18
the cap is what I need for it... my fault... brains not working good tonight
