10-20 OR 15-30?
DAVE
04-14-2004 03:57:33
I have what I was told was a McCormick Deering 10-20 tractor. It does not have a serial number tag. The number stamped on the motor is KC341544. The casting code numbers on the engine and other parts have a "D" code. Can someone tell me if this is indeed a 10-20. It has the steering shaft offset to the right. I read this was done on the 15-30. It does not have a power takeoff shaft. I thought 10-20's came standard with this. Any help would be appreciated.
Nebraska Cowman
04-14-2004 04:22:07
 Re: 10-20 OR 15-30? in reply to DAVE, 04-14-2004 03:57:33
It's a 10-20, the 15-30s had a TG prefix. Pto was an option on both tractors.
txblu
04-14-2004 10:36:27
 Re: Re: 10-20 OR 15-30? in reply to Nebraska Cowman, 04-14-2004 04:22:07
Heck, I thought you guys were talking about motor oil... Shows what I know about red.LOL
txBLU
DAVE
04-14-2004 09:21:29
THANKS. THE NUMBER ON THE MOTOR WOULD MAKE IT A 1929 IF I AM LOOKING AT IT CORRECTLY.
Nebraska Cowman
04-14-2004 10:15:36
 Re: Re: Re: 10-20 OR 15-30? in reply to DAVE, 04-14-2004 09:21:29
your number looks too high. crawl under the tractor. the date the main frame was cast will be back under the transmission.
