the open - decal
Bob G
04-14-2004 10:52:14
The only one i cant seem to figure has open, does it go on the radiator cap?
Paul in Mich
04-14-2004 19:41:20
 Re: the open - decal in reply to Bob G, 04-14-2004 10:52:14
Bob, The "open" decal is used when the tractor is equiped with radiator shutters. From the shutters, there is linkage which goes back to the steering post. Those tractors with belly pump had a bracket with 2 holes which accomodated the crank control for the shutters. Some models however had the control crank on the 4x4 plate below the lift control bracket. In either case, the "open" decal was placed to the left side or directly above the shutter control crank. If your tractor does not have shutters, there is no need to put the decal anywhere. Decal sets come with all decals, but not all are needed on all models. You only use what applies to your particular tractor. I'm sure you realize you dont apply one to your forehead. If you don't realize that, then maybe you do after all...Ha.
randy hall
04-14-2004 12:26:45
it's for the shutter control
Wardner
04-14-2004 12:54:39
 Re: Re: the open - decal in reply to randy hall, 04-14-2004 12:26:45
I agree. Near shutter crank terminus.
For owners of tractors without shutters, place decal on forehead.
CNKS
04-14-2004 17:57:18
 Re: Re: Re: the open - decal in reply to Wardner, 04-14-2004 12:54:39
That should read "empty".
Dave_Id
04-14-2004 10:55:50
I'm pretty positive it goes on the throttle plate
Steve W (NY)
04-14-2004 11:21:05
 Re: Re: the open - decal in reply to Dave_Id, 04-14-2004 10:55:50
That's funny....took me a minute....
