Super A Steering Rebuild
justin
04-14-2004 20:23:49
What parts are availible to rebuilt the steering box on a super a? the one we have is beyond adjustment. how much would we be looking at for the parts and where do you get em?
ugly in Tx.
04-15-2004 18:45:24
 Re: Super A Steering Rebuild in reply to justin, 04-14-2004 20:23:49
Justin I was quoted $650 for housing and all inside parts. that was parts only no labor. My friend fixed it for me. It only needed a $0.25 woodruff key. I painted the outside of his house furnished the woodruff key and he provided all the labor on the tractor. I am not good at working on any thing with gears in it. After he finished and played around a day on my super A he is now replacing the head gasket on his super H and putting it back to work, He said he had forgot how much fun a tractor is. ugly
Hugh MacKay
04-15-2004 02:25:18
justin: Have you had it apart yet? The reason I ask is those parts are very expensive. Which type of shaft is in that steering box? Older ones had a square tapered shaft and later ones have round tapered shaft with woodruff keys. Usually these can be repaired as very rarely are the worm or teeth of gear worn. The free travel is in the tapered shaft. On the type with the woodruff key I have seen free travel as much as full turn of steering wheel and it was all in keys and keyways.
justin
04-15-2004 20:07:53
 Re: Re: Super A Steering Rebuild in reply to Hugh MacKay, 04-15-2004 02:25:18
I dont know what shaft is in it. It isnt my tractor its my cousin's amd it darn near got a full turn of slop. the only thin i can tell ya is hat its the industrial front axel.
Hugh MacKay
04-16-2004 03:14:21
 Re: Re: Re: Super A Steering Rebuild in reply to justin, 04-15-2004 20:07:53
Justin: The industrial axle will not change the steering box. The only differences are the square or round shaft, and until that difference is known, kind of hard to tell you how to rebuild.
