what year is it
Darin green
04-14-2004 20:53:43
I have a farmall H that has been in my family for
30 years, i am trying to tell what year it is, but
the tag with the serial number is missing. is there any other way to tell????
Brad
04-15-2004 08:55:12
 Re: what year is it in reply to Darin green, 04-14-2004 20:53:43
The casting dates end with a letter, which indicates the year. For example P is 1946, Q is 1947, etc. I think the date codes are on this web site somewhere.
SAm in NS
04-15-2004 05:06:49
Look on the right hand side of the block, at the top, and near the front. Directly underneath the #1 spark plug. There will be a small raised flat spot on the block. You will probably need to clean the paint/grease off here but underneath there will be a serial #. This is the number of the engine and should be close to that of the tractor. Hope this helps, SAm in NS
pg
04-15-2004 02:44:31
there are casting codes on all the cast parts. letter at the end of code will tell you when casting was made. should be close to year made. whats the codes?
darin green
04-16-2004 21:10:09
 Re: Re: what year is it in reply to pg, 04-15-2004 02:44:31
The castings end with E and the # on the engine
right under #1 cyl is FBN-96322 HA 5X5. Does this
help any ?????
