Carburetor dozer blade questions
Butch
04-15-2004 13:42:26
I need to rebuild my carb. The tractor is a 1939 A, but has a 1951 vintage engine. The carb is a Zenith, but I can't find any numbers that look like the model numbers as shown in the OEM parts catalog. Anyone know how to figure out what model the carb is??
Also, I have a line on a dozer/snow blade from a Super A (with hydraulics), and I'm wondering if I can make it work on my non-hydraulic A?? Anyone have any suggestions??
Thanks!
Butch
Randy in NE
04-16-2004 04:32:59
 Re: Carburetor dozer blade questions in reply to Butch, 04-15-2004 13:42:26
If you call your local Case/IH dealer and give them a good description of the body of the carb and where different set screws and fittings are located on it they can most likely identify it for you. Or just take it off and take it along. About the only way to put hydaulics on an A would be to put a pto hydaulic pump on it along with an oil tank. You are not going to have live hydraulics. Every time you set the clutch you will lose hydraulics. It would be workable but not convenient.
Butch
04-17-2004 18:20:13
 Re: Re: Carburetor dozer blade questions in reply to Randy in NE, 04-16-2004 04:32:59
Actually I was thinking about the opposite tack. Taking a made-for-hydraulic blade and jimmying it to work on a tractor without hydraulics. That seems way easier than trying to jury rig hydraulics on an A..
Any ideas??
Tks!
Butch
