Oil pan gasket and oil pump cover gasket??
John
04-15-2004 15:20:28
I am going to be doing the oil pan gasket on my H, should I also replace the oil pump cover gasket? If yes, are there any tricks (use a sealer) to it, do I have to prime the oil pump? Thanks!!
Ed
04-15-2004 17:58:51
 Re: Oil pan gasket and oil pump cover gasket?? in reply to John, 04-15-2004 15:20:28
if it had good oil pressure i would just check the bolts....if not, i use "seal-all" on the gasket, its a clear glue that is gas & oil resistant....put a little grease or STP on the gears, it should start pumping itself with some type of lube on the gears
