Converting to 12 Volts
Scotty
04-15-2004 17:55:42
I am converting to 12v ign. but want to use my 6v ign. , Can I break the postive wire going to the coil and add a resistor to bring the voltage from 12v to 6v ? If so what type of resistor do I need and where can
I get one ? Thank you Scotty
Bob
04-15-2004 18:30:22
 Re: Converting to 12 Volts in reply to Scotty, 04-15-2004 17:55:42
Get a generic 12 Volt coil that states "no external reistor required, for about $5.00 to $10.00 more than a resistor will cost you, and save yourself a lot of agravation!
The problem with using a resistor is that not all coils draw the same current, so a certain value converting resistor that works well on on type of coil may be too low in value for use with another coil, causing rapid point wear, and an overheated coil, or with another coil the value may be too high, causing weak spark.
If you insist on a converting resistor, a "real" auto parts store should be able to come up with one to try. When you get it running, check for 5 to 7 Volts on the resistor (switch) side of the coil.
Scotty
04-15-2004 19:22:37
 Re: Re: Converting to 12 Volts in reply to Bob, 04-15-2004 18:30:22
Thanks Bob, I'm going to get a coil and try that. Every resistor the auto parts store gives me are 12v and 12v meaning 12v comes in one side and 12v out the other I don't get the purpose of that kind because i'd have to use about four of these resistors to get the voltage down to 6v...Thanks i'm trying the coil.
Scotty
Bob
04-15-2004 20:36:57
 Re: Re: Re: Converting to 12 Volts in reply to Scotty, 04-15-2004 19:22:37
Scotty,
Apparently you have tried a couple of resistors on your tractor?
The way a resistor works, it has to be powering a load (Current flowing through it) to show a voltage drop across the resistor.
You must have checked the voltage on both sides of the resistor with the breaker points open, so there was no current flowing in the ignition circuit. That is why you got the 12 Volts in and out.
If you still have one of the resistors, try it again, and start the engine, and use an analog voltmeter to check the voltage on the switch side of the coil for the 5-7 Volt range I posted before. If you are within that range, you SHOULD be OK.
The reason for using the analog voltmeter is that a lot of digital meters will be affected by the EMF produced by the ignition and charging system, and may go "nuts" and read incorrectly. An analog meter is less sensitive to the electrical "noise".
Scotty
04-16-2004 03:56:55
 Re: Re: Re: Re: Converting to 12 Volts in reply to Bob, 04-15-2004 20:36:57
Thanks Bob, this is some good stuff your telling me and I thank you for your time and patience
Scotty
