Crank Pin Help
Kent
04-15-2004 19:38:02
Having problems removing the crank pin on the crank shaft on my 1931 farmall regular. Banged on it a couple of times with good size hammer but couldnt get it to budge. Do I just need a bigger hammer? Or should I drill it out, or heat? Just trying to get to the front seal so it quits marking its territory. I have worked on SOB (Some Other Brands) tractors but this is my first regular. Any help would be appreciated! Thanks!
Dave@NY
04-16-2004 20:32:54
 Re: Crank Pin Help in reply to Kent, 04-15-2004 19:38:02
Soak it well with penetrant of choice.Have you losened the set screw? Takes a large flat blade screw driver.I had one come out with a few raps of the hammer.Last one I had to drill it out.Be carefull with the torch if you heat it.Too much heat on the end of the crankshaft might not be good.Good Luck!
Loren in Iowa
04-15-2004 19:45:49
There is a set screw that holds that pin in place.
