m gen
mike
04-16-2004 10:47:15
my winter project is about done, got a new gen belt from case ih part 352318DA and it's to short, looks like it needs to be 33 inches.the gen set high and clears the hood.the mounts look original, could the gen. end caps been put on wrong? if i rotate the ends it would set lower and the belt might fit . the tractor didn't have a gen. on it and i got one off a parts m. maybe i'll have to get another belt to make it work....thanks ,mike
49 Cubber!
04-16-2004 12:37:18
 Re: m gen in reply to mike , 04-16-2004 10:47:15
Turn the bracket that bolts to the head over.
Bob M
04-16-2004 12:08:22
Mike - The generator ends cannot be assembled wrong....they are doweled to the frame and will go together in only one position.
Could be your generator has the wrong sheave - should have a threaded adjustable pitch sheave similar to on the fan hub only smaller. Your best bet for a belt is your local hardware or mower shop. Buy sizes like an A32, A33 and A34, find the one that fits, then return the others.
