Does the engine oil run the hydrolics too???????
Farmallkid
04-16-2004 16:09:22
The hose that returns the hydrolic oil on my m is no good, i would guess it would be 15-25 years old. Where it hooks to the tractor it is leaking like crazy. my question is Does the engine oil run the hydrolics to? When i checked the oil a couple weeks ago it was above the top pitcock, when i started it today the hose started leaking, so i checked the oil and none came out the top check pitcock. i thought the hydrolics have a seperate resivore for oil. i will take the hose off and put a plug in.
paul
04-17-2004 11:03:15
 Re: Does the engine oil run the hydrolics too????? in reply to Farmallkid, 04-16-2004 16:09:22
No.
You will wreck the hyd pump if you do that.
There are belly & distributor hyd pumps; need more info to help you on what you have.
--->Paul
Dan Wa
04-16-2004 21:20:11
You need to get an operator's manuel and figure out what you got and what oil goes where.
Nebraska Cowman
04-16-2004 17:15:53
the hydaulics uses it's own oil. Do you have "live" pump?
