Hy-Tran in Super M transmission?
Tim Malin
04-17-2004 08:11:43
I was wondering if you could use Case IH Hy-Tran in the Super M transmission for the hydraulics and transmission. I know they normally say the 90wt gear oil, but I was wondering. I have heard of hy-tran in M's and stuff, but didn't know if that was a good thing or not, and now I need to put some in mine. Thanks.
CNKS
04-17-2004 12:58:52
 Re: Hy-Tran in Super M transmission? in reply to Tim Malin, 04-17-2004 08:11:43
There is no advantage to hytran in any M style tractor older than the SMTA. Just use 90W -- fewer leaks.
Aces
04-17-2004 09:59:48
Tim if your are talking SM I would stay with the 90 in the tranny, you could use hy tran in the hydraulic's, if you are talking SMTA then hy tran in the tranny.
steveormary
04-17-2004 10:35:34
 Re: Re: Hy-Tran in Super M transmission? in reply to Aces, 04-17-2004 09:59:48
Tim
CIH service manager said if seals were good I could use Hy-Tran. This was in an old M and a 300. And about ten years ago.
steve
JON
04-17-2004 12:45:48
 Re: Re: Re: Hy-Tran in Super M transmission? in reply to steveormary, 04-17-2004 10:35:34
I was told if yoy rebuilt your rearend and put newer type rubber seals in hy-tran is ok but our tractors came with leather seals and they leak to much without 90 wt.
steveormary
04-17-2004 20:03:16
 Re: Re: Re: Re: Hy-Tran in Super M transmission? in reply to JON, 04-17-2004 12:45:48
JON
What ever works I guess. I never had any leaks using Hy-Tran. I bought the tractor used and it seemed it had never been worked hard or abused. I used it for loader tractor. Set it under an F-10 Farmhand cable loader.
steve
