radiator fluid coming out of bottom of bell housin
Huston Lloyd
04-18-2004 13:52:05
what will make radiator fluid come out of the bottom of a farmall 140 1966 tractor for unkown reason it started all of a sudden?
thanks apical188
Hugh MacKay
04-18-2004 14:17:06
 Re: radiator fluid coming out of bottom of bell ho in reply to Huston Lloyd, 04-18-2004 13:52:05
Huston: Just looked at the IT manual and there is indeed frost plugs one on each side about 3 to 4 inches above the level of center line of crank. Like RLS. said it has to be one of those rusted.
RLS ia
04-18-2004 13:59:33
There is a freeze plug at the rear of the block that could be rusted out. I can't remember if its above or below the bellhousing.
Huston
04-18-2004 18:35:47
 Re: Re: radiator fluid coming out of bottom of bel in reply to RLS ia, 04-18-2004 13:59:33
thanks for your info i will look for it.
