M FARMALL NEEDS TRANSPLANT
red man
04-18-2004 17:25:48
Has anyone out there put a cummins enjine in a M? I HAVE a 3.9 that looks like it would fit the frame and tractor about like the old gasser. should make for plenty of tourque and run all day on very little fuel.
r4etired
04-18-2004 18:04:35
 Re: M FARMALL NEEDS TRANSPLANT in reply to red man, 04-18-2004 17:25:48
Never tried a cummins but I know a 345 IH V8takes all the room you have. Fitting a govenor alternator,power steering pump,and relocating the oil filter fills it up. I don't lengthen or widen the frame rails.If you take out the hand crank shaft you have less than 30 in from clutch housing to steering casting. anything can be done Good luck
