Farmall B Exaust lift
donwisc
04-18-2004 20:03:18
I picked up a B on an auction today and it has the the big cylinder on the left side which works off of the exaust.
I want to rebuild it and wonder if any of you have a manual or breakdown of the system. I would be glad to pay for the cost to reproduce and send a copy.
DENNIS IN NC
04-26-2004 14:14:52
 Re: Farmall B Exaust lift in reply to donwisc, 04-18-2004 20:03:18
got a 39 b with working lift what do you need to know
donwisc
04-27-2004 19:50:24
 Re: Re: Farmall B Exaust lift in reply to DENNIS IN NC, 04-26-2004 14:14:52
I have a number of questions that might be better if we discussed by phone. If you dont mind giving me your number to donmakan@msn.com Ill call you.
Thanks for the response Dopn
donwisc
04-19-2004 18:45:05
Thanks Gene Ill keep you in mind when I inventory what I I have.
Brad
04-19-2004 09:54:02
There are several companies that sell reprints of the lift-all operator's manual. Do a web search for IHC manuals, this forum won't allow me to include a link here for you(competition).
gene b
04-19-2004 02:47:48
There is more than just the big cycl to make it work. How good is the rest of the system is it all there? When you pull the lever back it should raise the piston. The return is brought down by the wt of the cult. If the cycl is on the left side where the lite is that is the position for the cult. The cycl bolts to different places for other implements. You can also check out the cycl by using air pressure from compressor. I have four systems working and some parts.
