Super A popping out the carb....
AC
04-18-2004 20:11:38
Got my SA running today. I have the timing right on, the valves don't seem stuck, holds 75 psi compression accross the board, and the carb works well. BUT it pops irregularly out the carb, and I think it is just in one cylinder. When it idles, it is fine, but as soon as I rev it up, it just can't do it, and begins to pop...any thought or suggestions? I really don't want to pull the head....It would run just about perfectly if I could fix this..... .thanks.....AC
AC
04-19-2004 18:25:24
 Re: Super A popping out the carb.... in reply to AC, 04-18-2004 20:11:38
you guys are dealing with the biggest idiot out there...I had the two middle wires switchted! lol...thanks, plus I think a valve was a bit stickey, and a few wacks cured that...thanks..... AC
joe
04-19-2004 11:52:50
Make sure all your exhaust valves are opening, could be a lobe off of the cam, and the exhaust is trying to exit threw carb side. just something to check.
SAm in NS
04-19-2004 03:48:13
Are you sure you don't have a sticky valve? Not actually stuck and works fine when you turn it over at idle speed but just can't keep up at higher RPM. I don't know how you could check. Hope this helps, SAm in NS
gene b
04-19-2004 02:40:34
Have you tried new plugs? Are you showing 34deg advance at full throttle. Have you changed over to 12v and are not using the rite coil? These are just a few things that could be wrong.
