steps to remove Radiator on FARMALL M
Brad
04-18-2004 20:26:10
What do I do? It looks like the steering runs thru the top of the radiator. . . Do I need to disconnect it? what else? Thanks
One more thing.
04-19-2004 04:54:45
 Re: steps to remove Radiator on FARMALL M in reply to Brad, 04-18-2004 20:26:10
Some of the early Ms do not have holes in bolster to access radiator bolts. Makes getting bolts out a little more fun.
oliver is it
04-19-2004 04:00:45
well read all the posted tips and you should have it figured out but you might want to take pipe and cap out of bottom of radiator and let drain in a bucket before you pull hoses might not have near the mess.
Farmer Bob
04-18-2004 21:55:16
Yes the steering shaft has to be removed. Unscrew the large plug at the top of the upper bolster. Loosen the clamp at the u-joint by the gauges and screw the shaft out through the front of the upper bolster. Disconnect the upper radiator support bar and upper radiator hose. Loosen the clamps on the bottom radiator hose. Take the fan shroud off. Remove the cotter keys and castellated nuts from the two studs in the bottom of the radiator that go through the base of the bolster. Pull the radiator up and away from the fan blade.
Can't recommend strongly enough that you invest in a service manual!!! A Parts manual is just as valuable as well as an Operators Manual.
joy
04-22-2004 20:43:48
 Re: Re: steps to remove Radiator on FARMALL M in reply to Farmer Bob, 04-18-2004 21:55:16
glad to know that we aren't the only ones that had this problem. However what do they mean by bolster??? The frame piece on the side??? If you can't get the worm gear out take a pipe wrench gently to the steering shaft and turn the shaft and bearing out. good luck.
Dave_Id
04-18-2004 21:55:10
I don't remember having much grief with removal of the radiator, you do have to take that big hex nut off the upper bolster, and remove the steering wheel shaft out first, take off the hoses, and unscrew it from the bottom and wallah!!!
r4etired
04-19-2004 19:53:53
 Re: Re: steps to remove Radiator on FARMALL M in reply to Dave_Id, 04-18-2004 21:55:10
One more step I recommend, soak the bottom bolts with a good penetrating oil a couple of times before you try to remove them, it is a real pain to make a plate and braze the bolts on and solder it to the lower tank. Been there.
Farmer Bob
04-18-2004 21:56:57
Sorry Dave, didn't see you typin and the same time I was.
