Finishing the sleeve puller.
Loren
04-18-2004 20:48:24
Finally have a bit more time to make the sleeve puller for my B. I have one more question though first. Are the sleeves tight the full length or are they relieved and will slide free after an initial pull? In other words, since I sem to not word things well, am I going to have to PULL them full lenght or not? If not, how far? Thanks, Loren.
Thanks for the help guys.
04-19-2004 20:20:11
 Re: Finishing the sleeve puller. in reply to Loren, 04-18-2004 20:48:24
Loren
Brad
04-19-2004 09:46:45
Once they pop loose and move a half inch or so they should come the rest of the way with ease.
gene b
04-19-2004 02:34:57
Only have to pull a little over an inch.
riverbend
04-19-2004 07:01:23
 Re: Re: Finishing the sleeve puller. in reply to gene b, 04-19-2004 02:34:57
On my H they had to be pulled all the way up, so I guess it depends.
Red Dave
04-19-2004 11:50:26
 Re: Re: Re: Finishing the sleeve puller. in reply to riverbend, 04-19-2004 07:01:23
Yep, it depends on what kind of engine it is. The B has a wet sleeve engine. Your H is dry sleeve.
