Replacement rubber boots for tie rod ends availabl
Greg
04-19-2004 07:12:18
My IH 364 diesel w/power steering needs the rubbers at the tie rod ends replaced. Also has 2-3 more of the same type boots in the steering system that need replacing. They are deteriorated from weather but the tie rod joints themselves are still good. Can I buy the rubber boots and just replace them? What are good sources?
RPM
04-19-2004 10:54:25
 Re: Replacement rubber boots for tie rod ends avai in reply to Greg, 04-19-2004 07:12:18
Usually 358900R1 boots for 400/560/806/1486 will fit, (CNH part number).
Greg
04-19-2004 11:39:00
 Re: Re: Replacement rubber boots for tie rod ends in reply to RPM, 04-19-2004 10:54:25
Thanks for that information. From your experience, will the above boots you listed fit just the tie rod ends or will they fit at the other steering joints as well? With power steering on my 364 there is one of the boots at both ends of the link that runs from the steering wheel to the power steering cylinder - are these the same as the tie rod ones? Thanks.
RPM
04-19-2004 16:27:15
 Re: Re: Re: Replacement rubber boots for tie rod e in reply to Greg, 04-19-2004 11:39:00
If the size is close the new boots will be flexible enough new rubber you can use them anywhere. I have never worked on any 464 but these boots will usually work for about anything close, better than nothing anyhow.
