Generator problems
Kenny K
04-19-2004 17:24:35
Does any Farmall H ever stay without electrical problems???? Last fall she was runnin beautiful, started right up, generator charging no problems. Now she stopped charging when she's running the ammeter shows a slight discharge. When I take off the negative battery lead she stalls out. That means she's running on battery juice, right? How can I tell if the generator is puttin out. Can anybody help?????/
Thanks Kenny K
bugsy
04-19-2004 19:58:15
 Re: Generator problems in reply to Kenny K, 04-19-2004 17:24:35
K, Clip your volt meter on the generator and see how many volts it's putting out.
Bob M
04-19-2004 18:15:49
Like the Nebraska Cowman suggests, generator systems are fussy compared to alternators - they require periodic care and feeding if you expect them to continue to work...
Depending on whether your H has a cutout or voltage regulator, one of the flow charts (punch below, then look at the bottom right corner of the page) can help you figure out where the problem is.
Bob
04-19-2004 17:58:42
Check your battery voltage. You can use a simple $10.00 analog meter from Wally World. If the battery has been sitting overnight or longer, it will have dropped to 6.3 Volts, or less. With the tractor running, the voltage should be between a minimum of 6.9 Volts and a maximum of 7.5 Volts.
Nebraska Cowman
04-19-2004 17:43:04
my thoughs exactly. everybody wants to take off the alternater and go back to the "original" generator. They spend a lot of time and money getting it working and then expect it to stay that way. well folks, it just ain't so. Generators take a lot of maid setting. sand paper the armiture and ground out the field terminal and see if it don't go to charging.
