cummins conversion
shultz
04-20-2004 04:46:08
I remember reading on here a while back about an outfit out west that is making cummins conversion kits for IH tractors. I was wondering if anyone has any contact info on the place. I didn't think about it at the moment, but we have an old 400 rear sitting around and were thinking of finding a regular gas motor to put into it, but I'd sure think it would be a lot more useful and ecnomical with a 4 cyl. cummins under the hood - and would be a little out of the ordinary too. Since the bell housing is the same on them as the bigger tractors, I'd think tha backing plate would basically be the same as the bigger tractors.
Thanks for any info!
26Red
04-20-2004 11:16:07
 Re: cummins conversion in reply to shultz, 04-20-2004 04:46:08
The cummins 4BT would be a good fit. Tricky part would be setting up the flywheel/drive spline because you have a separate shaft for the live pto.. Check out this Oliver site for cummins conversions.
Steve from Mo
04-20-2004 07:15:24
The conversions that were done when those tractors was newer would have been a GM engine. Several companies did them for Farmall and Case tractors.
There was also a 400 diesel based on the IH gas-start engine. Finding an engine from a dozer, grader, or power unit might be possible but they tell me repairs are costly.
red man
04-20-2004 05:55:24
i have a question on page 3 of this forum about the same thing so far omly one response/not much help.i am sure someone out there makes a kit to install a cummins in various things. good luck ,if you find out let me know ,please?
shultz
04-20-2004 10:37:22
 Re: Re: cummins conversion in reply to red man, 04-20-2004 05:55:24
I did a search and found the following discussion a while back. I did a gogle search and found link implement's telephone # - I might give them a call some day just out of curiosity and see what they have to say.
http://www.ytmag.com//farmall/messages/408060.html
