Removeing paint
VanO
04-20-2004 10:51:30
I have a Farmall modle H and some one has painted over the plate with the serial number on it. How can I take off the paint without removing the writing from the plate?
Thanks from VanO
Andy
04-21-2004 10:02:46
 Re: Removeing paint in reply to VanO, 04-20-2004 10:51:30
Van O,
You could try elctrolysis, which if done correctly should remove the paint and not bother the plate at all. All you need is a battery charger, a tub, and a little time. Check out
Link
for more info. (I know it is a green page, but this guy is good).
Harlen Larson
04-20-2004 17:49:42
Most paints people use on tractors are low grade enamels. Laquer thinner would most likely wipe it off. Good Luck
bigrerddm
04-20-2004 17:23:41
try using paint stripper. brush it only on the tag.
