Overheating
Bill
04-20-2004 15:25:14
I've seen several posts about tractors that have set up for years and are restored to running condition only to overheat and crack a head because of clogged water passages. Other than removing the head for a visual inspection and cleaning, is there a way to tell if there is a problem with clogged passages?
Thanks
riverbend
04-20-2004 20:14:59
 Re: Overheating in reply to Bill, 04-20-2004 15:25:14
I'd rather take the head off my H than remove the radiator. It seems like the peace of mind would be worth a valve grind gasket set and the time to re-torque (or even re-re-torque) the head.
Dave_Id
04-20-2004 15:32:26
If indeed we are talking "restoration", I don't know of anyone, myself included that doesn't automatically send the radiator in to be rodded out while they have the machine apart for restoration, unless they know it's not plugged.
Bill
04-20-2004 15:36:43
 Re: Re: Overheating in reply to Dave_Id, 04-20-2004 15:32:26
In this case restoration may be a stretch. I've replaced seals, gaskets, etc. and it get body work and paint, but I was avoiding getting into the engine because it runs great.
